lumix cmd SZ10 Firmware aktualisieren funktioniert nicht
tomass
Beitrag von tomass » Dienstag 5. Mai 2020, 14:20
Hello,
I have followed the firmware update instructions from 1.0 to 1.2 version and I am not able to achieve this operation. The camera system keeps always 1.0. I have tried everything - the transition from 1.0 to 1.1 (jp->en), 1.0 to 1.2 (jp->en), 1.0 to 1.2 (jp->jp). After one second I have this message: "バージョンアップ完了" and then approximatively after 3 seconds the LCD switches off without any result. Unfortunatelly I am nor able to debug this situation furtherelly neither I am able to find any trace of the solution on the forums. If you want I can send you the video of the screen.
I used: https://av.jpn.support.panasonic.com/su ... ndex2.html
and also this: https://av.jpn.support.panasonic.com/su ... tep_n.html
I looked also for this: viewtopic.php?f=84&t=10930
I downloaded always CK36400.elf of 40501440 Bytes. I enclose the photos and a short video of the process: here.
Did you heard about this kind of behaviour? Could you give me some hint please?
Thank you very much in advance,
Kind regards,
Tomas.
