Elpro, Nahlinse, Close-Up Lens, Übersicht, Summary
schluchtenscheisser
Vielleicht von Interesse.
Leica, ELPRO, Close-Up Lens
Dioptric, Diopter, Focal Length, Object Field, Reproduction Ratio
Elpro 1 2,51 dioptric 399,04mm focal length
50mm f/2 Summicron-R II 184x276 / 91x137 mm Object Field
Elpro 2 4,92 dioptric 203,45mm focal length
50mm f/2 Summicron-R II 94x141 / 62x93 mm Object Field
Elpro 4 0,75 dioptric 1333,57mm focal length
100mm f/4 Macro-Elmar-R 323x484 / 61x92 mm Object Field
100mm f/4 Macro-Elmar-R with Macro-Adapter-R 63x94 / 34x51 mm Object Field
135mm f/2.8 Elmarit-R II 237x355 / 106x159 mm Object Field
180mm f/4 Elmar-R 176x267 / 80x 120 mm Object Field
Elpro 3 1,66 dioptric 602,56mm focal length
90mm 2.8 Elmarit-R II + 90mm 2 Summicron-R 161x241/ 72x108 mm Object Field
100mm f/4 Macro-Elmar-R 145x218 / 48x72 mm Object Field
100mm f/4 Macro-Elmar-R with Macro-Adapter-R 49x43 / 29x44 mm Object Field
135mm f/2.8 Elmarit-R II 107x160 / 66x99 mm Object Field
180mm f/4 Elmar-R 80x120 / 48x72 mm Object Field
50mm f/2 Summicron-R II infinity / 0.5m
Type 1 - 184x276 / 91x137 mm Object Field - 2.51 dioptric – 1:7.7 / 1:3.8
Type 2 - 94x141 / 62x93 mm Object Field - 4.92 dioptric – 1:3.9 / 1:2.6
90mm f/2.8 Elmarit-R II + 90mm f/2 Summicron-R infinity / 0.7m
Type 3 - 161x241 / 72x108 mm Object Field - 1.66 dioptric – 1:6.7 / 1:3.0
100mm f/4 Macro-Elmar-R infinity / 0.6m
Type 4 - 323x484 / 61x92 mm Object Field - 0.75 dioptric – 1:13.0/1:2.5
Type 3 - 145x218 / 48x72 mm Object Field - 1.66 dioptric – 1:6.0 / 1:2.0
100mm f/4 Macro-Elmar-R with Macro-Adapter-R infinity / 0.6m
Type 4 – 63x94./.34x51 mm Object Field - 0.75 dioptric – 1:2.6 / 1:1.4
Type 3 – 49x43 / 29x44 mm Object Field - 1.66 dioptric – 1:2.0 / 1:1.2
135mm f/2.8 Elmarit-R II infinity / 1.5m
Type 4 - 237x355 / 106x159 mm Object Field - 0.75 dioptric – 1:9.9 / 1:4.4
Type 3 - 107x160 / 66x99 mm Object Field - 1.66 dioptric – 1:4.5 / 1:2.8
180mm f/4 Elmar-R infinity / 1.8m
Type 4 - 176x267 / 80x 120 mm Object Field - 0.75 dioptric – 1:7.4 / 1:3.3
Type 3 - 80x120 / 48x72 mm Object Field - 1.66 dioptric – 1:3.3 / 1:2.0
75-200mm f/4.5 Vario Elmar R at 75 mm infinity
Type 4 - 414x621 mm Object Field - 0.75 dioptric – 1:17.3
Type 3 - 187x281 mm Object Field - 1.66 dioptric – 1:7.8
75-200mm f/4.5 Vario Elmar R at 200 mm 1.2m
Type 4 – 62x93 mm Object Field - 0.75 dioptric – 1:2.6
Type 3 - 41x62 mm Object Field - 1.66 dioptric – 1:1.7
80-200mm f/4.5 Vario Elmar R at 80 mm infinity
Type 4 - 392x588 mm Object Field - 0.75 dioptric – 1:16.3
Type 3 – 177x266 mm Object Field - 1.66 dioptric – 1:7.4
80-200mm f/4.5 Vario Elmar R at 200mm 1.8m
Type 4 - 83x125 mm Object Field - 0.75 dioptric – 1:3.5
Type 3 - 50x75 mm Object Field - 1.66 dioptric – 1:2.1
Re: Elpro, Nahlinse, Close-Up Lens, Übersicht, Summary
- grinsinnelins
Was soll uns das bitte sagen, wenn Du die Dinger verkaufen willst, gibt es dafür den Marktplatz ! Gruß Bernhard
schluchtenscheisser
"Interesse " bezieht sich auf den Inhalt der Zusammenstellung und nicht auf ein Verkaufsangebot.
Gruß Walter
Gruß Walter
- wozim
Das beantwortet keine Frage.
Was willst du uns jetzt damit sagen?
saSasch
Vorsicht, Wozim reagiert empfindlich auf falsch eingestellte Verkaufsangebote!
Lumix G81, Pana 25mm 1.4, Sigma Art 60mm 2.8, Pana 12-32, Olympus 45mm 1.8, Panasonic 100-300
Das es sich hier um kein Verkaufsangebot handelt könnt ihr in der Einleitung sehen.
Er mach hier eine Aufstellung der Objektive Leica, ELPRO, und Close-Up Lens
mit den zugehörigen Parametern
leider blieb er uns eine Antwort schuldig warum er mit uns diese Aufstellung teilen möchte,
für was sie nützlich ist und was wir damit anfangen können.
Vielleicht tut er das ja noch.
Für Leute, die solche Leica-Sachen haben und teilweise auch noch auf einer Lumix verwenden, ist das eine durchaus brauchbare Information. Vielen Dank dafür.
Klaas
Klaas
Etwas Kontextinfo fehlt, aber vielleicht ist das ja gerade das spannende: Das Gehirn ist gut darin, fehlende Information eigenmächtig durch daher Assoziiertes zu ersetzen.
Meines sagt mir gerade: Baue einen Blitzdings mit MFT Linsen ...
schluchtenscheisser
Antwort des Threadbeginners
Löbliche Mitglieder!
Mit meinem ersten Beitrag habe ich die Intention, detailierte Daten über die Elpros zur Verfügung zu stellen.
Der Bedarf besteht dafür. Als Beispiel:
"http://www.lumix-forum.de/viewtopic.php ... pro#p83697
Re: 2 Makrolinsen, aber kein gutes Ergebnis!
Welche Brechzahl (Dioptrien) hat denn das Elpro 3?"
Ich betone nochmals, daß von mir keinerlei Absicht irgendeiner Verkaufsanbahnung besteht.
Sehr geehrter Herr Dominik ("Dom")!
Ich ersuche Sie mir mitzuteilen, aufgrund welcher Überlegungen Sie schließen,
daß der Verfasser eines derartigen Beitrages ein "Forentroll" ist.
Hochachtungsvoll
Walter Raber
Hochachtungsvoll
Walter Raber
Ohne Vorurteile wie ich bin, (abseits jedglicher gleich Löschung oder Ignorieren Aufrufe wie man sie sofort findet
), sage ich schlichtweg: Willkommen im Forum, viel Spass und auf einen regen Erfahrungsaustausch.
Die Tatsache,dass eine technisch fehlerhafte Aufnahme gefühlsmäßig wirksamer sein kann als ein fehlerloses Bild, wird auf jene schockierend wirken, die naiv genug sind zu glauben, dass technische Perfektion den wahren Wert eines Fotos ausmacht.- A.F.
Valentino
Hallo Walter,
Du hast ein Forum mit einem sehr angenehmen Tonfall gefunden. Wir gehen alle respektvoll miteinander um. Allerdings ist mir kein User bekannt der voller Hochachtung vor anderen Lumixern ist.
Die allgemein gebräuchliche Anrede im Internet ist das "Du". Genau das pflegen wir auch hier in diesem Forum. Dein Auftreten mit unkommentierten Daten in Verbindung mit der Anrede "Sie" wirkt befremdlich und trägt sicherlich wenig zur Akzeptanz Deiner Person hier im Forum bei.
Komm einfach von Deiner Wolke auf unsere Ebene herunter, lass uns einen virtuellen Kaffee miteinander trinken und schreib ein bischen was über den Hintergrund Deiner Anmeldung, Deiner Ausrüstung und Deinen Vorstellungen vom fotografieren.
Herzlich willkommen
Herzlich willkommen
schluchtenscheisser
Hallo Valentino,
Danke für Deine netten Zeilen.
Du hast mir die Usancen eines Internetforums treffend beschrieben.
Gerne nehme ich Deine Ideen an.
Als Besitzer einer G1 und GH2 werde ich in diesem Forum sicher viel Wissenswertes erfahren und vielleicht mit Informationen ein wenig beitragen können.
Beim zweiten Mocca sitzend
liebe Grüsse
Walter
liebe Grüsse
Walter
- mikesch0815
Na, dann mal herzlich willkommen im Forum.
