und schon gibt es ein Firmware Update für die GH6.
https://av.jpn.support.panasonic.com/su ... index.html
V1.1:
When a RAW image shot in High Resolution mode was developed using RAW development software, there were cases where false color occurred in the developed image. This issue has been resolved.
Thorsten
Neue Firmware für die GH6
- Thorsten_K
So einiges an Equipment...
- Thorsten_K
Re: Neue Firmware für die GH6
und schon wieder ein update..
https://av.jpn.support.panasonic.com/su ... l/gh6.html
Apr. 5, 2022
Ver.1.2
There were cases where magenta or green cast was seen on the live view image during photo shooting/video recording. This bug has been fixed.
When recording video in [5.7K/5.8K] with a wide-angle lens and the [E-Stabilization(Video)] is set to ON, there were cases where particular part of the image frames were vertically shifted throughout the footage depending on the focal length. This bug has been fixed.
Thorsten
Apr. 5, 2022
Ver.1.2
Thorsten
- Thorsten_K
am 5 Juli soll die Firmware Version 2.0 herauskommen.
Anbei die Neuerungen.
https://www.prnewswire.com/news-release ... 63331.html
Thorsten
Thorsten
- Thorsten_K
die Version 2.0 ist raus.
Jul. 5, 2022
Ver.2.0
RAW video data output over HDMI
- [5.7K] / [C4K] / [Anamorphic (4:3) 5.8K] / [Anamorphic (4:3) 4.4K] 12-bit RAW video data can be output over HDMI to ATOMOS NINJA V and NINJA V+ devices, to be recorded as Apple Pro Res RAW.
* All functions may not be available depending on the situation.
* NINJA V+ supports all RAW video data. NINJA V does not support some RAW video data.
* Software that supports Apple ProRes RAW is required to edit RAW video recorded with NINJA V/V+.
* A LUT (Lookup table) exclusively designed for RAW video is available on the following customer support website to make the same color grading as V-Log/V-Gamut.
https://panasonic.jp/support/global/cs/ ... h_raw_lut/
Added video recording modes
- Below Apple ProRes 422 HQ/ProRes 422 video recording modes are available.
* C4K59.94p, 50p, 29.97p, 25p, 24p, 23.98p
* FHD59.94p, 50p, 29.97p, 25p, 24p, 23.98p
Expanded compatibility with DJI Gimbal
- Active Track Function of DJI Gimbal "DJI RS 2" and "DJI RSC 2" can be used.
For details, please check the DJI official announcement.
· DJI RS 2 Release Notes
· DJI RSC 2 Release Notes
Operating Instructions for the Change of Specifications
Thorsten
Jul. 5, 2022
Ver.2.0
Thorsten
- Thorsten_K
wieder eine neue Pressemitteilung von Panasonic zur GH6. Firmware 2.2 am 27. Sep. 2022
Bitte den Link folgen...
https://www.panasonic.com/de/corporate/ ... x-gh6.html
Thorsten
Thorsten
